TwinTurbo.NET: Nissan 300ZX forum - No compression in cylinders
Zcrazy521
on July 25, 2011 at 1:13 PM
Before we into a discussion on how to accomplish
posted by JMartz
on July 25, 2011 at 12:38 PM
The car started to run with a real rough idke the eventually just would start. I check the compression and had. Nothing in 3 cylinders 2 on one side 1 on the other
Cylinder heax replacing
Zcrazy521
12:02:39 07/25/11
Fish inside
Poppe
12:19:20 07/25/11
JMartz
12:38:55 07/25/11
No compression in cylinders -
Zcrazy521
13:13:59 07/25/11
Do a leak down first.
Draker (Eugene, OR)
13:37:14 07/25/11
Re: Do a leak down first.
Zcrazy521
13:39:51 07/25/11
To remove the heads you will have to remove the
JMartz
13:57:43 07/25/11
Re: To remove the heads you will have to remove the
Zcrazy521
14:10:56 07/25/11
Here
Draker (Eugene, OR)
14:46:02 07/25/11
Draker sent you link but I will give you a quick
JMartz
15:37:19 07/25/11
This is basically how you do it.
Draker (Eugene, OR)
16:12:52 07/25/11
I replaced the cylinder heads with the engine in
supermario680
08:16:57 07/29/11
