TwinTurbo.NET: Nissan 300ZX forum - I just flushed and filled the system about a month ago,
pchock
on July 24, 2011 at 2:05 PM
A couple other things you might do/check.....
posted by RonZ300 (Socal)
on July 24, 2011 at 01:32 PM
so that shouldn't be a problem. I'll make sure to hose down everything you said. Thanks for all the help.
Car overheats with A/C running.
pchock
16:03:21 07/23/11
Re: Car overheats with A/C running.
pchock
16:14:25 07/23/11
Is your ac auxillary fan working?
Russell.DiVittorio
19:59:43 07/23/11
Yes, the fan is working.
pchock
01:58:12 07/24/11
Does the fan turn on right when you turn the key on? In the
Russell.DiVittorio
08:17:02 07/24/11
No, just after the temperature has reached north of halfway,
pchock
11:49:31 07/24/11
Aux fan hould turn on wehn temp reches 180F, I believe. (n/m)
JMartz
16:57:15 07/24/11
Take out your radiator and hose it down, clean out the core. (n/m)
RonZ300 (Socal)
09:55:26 07/24/11
I'll try this out. thanks. (n/m)
pchock
11:50:12 07/24/11
RonZ300 (Socal)
13:32:03 07/24/11
I just flushed and filled the system about a month ago, -
pchock
14:05:09 07/24/11
I have been recently working on my a/c due to insufficient
JMartz
17:06:54 07/24/11
Thermostat? Fully opening and allow enough water to pass? (n/m)
Gordo 93TT Daytona
11:44:47 07/25/11
What are actual temps of system? Are you using the dash
Gordo 93TT Daytona
11:49:54 07/25/11
So, I took out the radiator and hosed it, the condenser, and
pchock
16:03:28 07/25/11
Be advised your dash temp gauge is NOT linear. It moves to
Gordo 93TT Daytona
21:22:23 07/25/11
