TwinTurbo.NET: Nissan 300ZX forum - Painters Requested - Sanding Advice Needed
Subject Painters Requested - Sanding Advice Needed
Posted by evan_aggie on July 23, 2011 at 8:37 PM
  This message has been viewed 295 times.
Message I put down 3 layers of epoxy primer.
I then put down 2 layers of Metalux black. The base coat wasn't quite as smooth as the primer. I tried to sand (test sand anyway) with 2000 grit and as you can see, it dulled out the finish. Do you have to use a buffing compound after 2000 grit?
