TwinTurbo.NET: Nissan 300ZX forum - Re: Center grill temperature range...
Subject Re: Center grill temperature range...
Posted by Stadsport (PHX) on July 23, 2011 at 4:52 PM
  This message has been viewed 114 times.
In Reply To Center grill temperature range... posted by JMartz on July 23, 2011 at 01:53 PM
Message When the A/C is on, the only thing that turns the compressor off is the pressure switch. The throttle suction valve controls how much refrigerant is flowing through the evaporator.
I would check your refrigerant pressures, it sounds like you're just low, but make sure before you start putting in more refrigerant.
