TwinTurbo.NET: Nissan 300ZX forum - Messed up one headlight
Subject Messed up one headlight
Posted by Shawman on July 22, 2011 at 9:42 PM
  This message has been viewed 127 times.
Message First of all, I wanted to let you all know that I'm quite retarded, apparently. I was trying to install some HIDs in my girlfriend's car and didn't do any research on it. Turns out that the leads are reversed in the LS400 fog light wiring, which is why they wouldn't turn on. In the process of discovering this, however, I used a DMM on my 300zx headlight as an Ammeter, shorting the two leads on my drivers side headlight. Now, when plugged back in, my driver side headlight flickers but won't stay on, like it can't draw enough current. I swapped the hi/low relay with another and still had the same problem. I also don't think a fuse would make a difference since they're on the same circuit.
Anyway, please help. Where should I be looking? Are there some hidden fuses or spots I should check for bad wiring? Is there more than one headlight relay that could be out?
Also, now is a good time to spam n00b comments, just please provide some useful info when you spam. Thank you.
