TwinTurbo.NET: Nissan 300ZX forum - I ran a ground to the frame as a temp fix.
ELDIABLO
on July 21, 2011 at 10:52 AM
Thanks for the tip.
posted by JMartz
on July 19, 2011 at 07:24 PM
May be a bad connection. After I R&R'd my engine, the a/c worked fine without my ghetto ground wire.
Soy dios y soy el diablo
Air conditioning question...
JMartz
10:06:56 07/19/11
Did you check the wire coming off of the compressor?
Woody75 (Denver)
10:20:44 07/19/11
Hey Woody, removed shroud, fan and rad to gain access
JMartz
12:53:41 07/19/11
Re: Hey Woody, removed shroud, fan and rad to gain access
Onyxblue
17:06:03 07/19/11
Thanks for the tip.
JMartz
19:24:32 07/19/11
I ran a ground to the frame as a temp fix. -
ELDIABLO
10:52:24 07/21/11
you're probably overcharged unless you had a leak
aliaZ
22:28:19 07/20/11
stop guessing and throw some gauges on your system
aliaZ
17:25:29 07/19/11
Adding refigerant did not restart the compressor. (n/m)
JMartz
09:03:41 07/20/11
Figured out the problem...
JMartz
09:02:41 07/20/11
the same happened to my 240sx
aliaZ
22:26:31 07/20/11
