TwinTurbo.NET: Nissan 300ZX forum - Your clutch master is failing.....
Subject Your clutch master is failing.....
Posted by Greg D. (Specialty-Z) on July 20, 2011 at 7:20 PM
  This message has been viewed 124 times.
In Reply To Clutch pedal travel issues posted by Obeeone on July 20, 2011 at 01:10 PM
Message The master is what builds the pressure, the slave does the work when the pressure gets there.
If the slave dies, you can loose pressure, but the fluid also leaks out.
The master can bypass and not leak much.
When the master gets weak, it is harder to build pressure, after pumping a few times the seal can expand and make pressure again.
