TwinTurbo.NET: Nissan 300ZX forum - I had the battery lead shake off the starter once
Subject I had the battery lead shake off the starter once
Posted by BlackholeZ on July 20, 2011 at 6:29 PM
  This message has been viewed 96 times.
In Reply To car wont start posted by Napoleon34 on July 20, 2011 at 02:21 PM
Message Damn rough roads.
If this is the problem, you turn the key and get a single click, and when you release the key, another single click.
If your battery is dead, turn on the headlights and try to crank. The headlights will practically turn off and your dash lights will dim badly. There also may be several clicks as the solenoid bounces because of having insufficient current. If you push start the car your alternator will whine a bit because it is heavily loaded max charging the battery.
-Dan
"Capitalization is the difference between helping your Uncle
Jack off a horse, and
helping your uncle jack off a horse."
"'she' also likes to swap since I think I am going to need
to give her to woody again."
- Dvlhntr
"full alphabetic boost mode"
ChristopherTheOne
"Two oil eating, angry, spinning triangles of death." -
turtleboy on rotary engines
