TwinTurbo.NET: Nissan 300ZX forum - Figured out the problem...
Subject Figured out the problem...
Posted by JMartz on July 20, 2011 at 9:02 AM
  This message has been viewed 137 times.
In Reply To Air conditioning question... posted by JMartz on July 19, 2011 at 10:06 AM
Message I noticed the system worked by simply bypassing manually the a/c relay. That meant the dual pressure switch was letting curent through. Looking at the wiring diagram I saw that the ECU provides the ground to energize the a/c relay. My ECU had ceased to accept communication with my ConZult program. That was the final clue. A "new" ECU made the a/c work. Apparently the grounding transistor for this circuit is toast as the ECU runs the engine just fine.
Weird, unexpected and hard to diagnose problem.
