TwinTurbo.NET: Nissan 300ZX forum - Re: Hey Woody, removed shroud, fan and rad to gain access
Onyxblue
on July 19, 2011 at 5:06 PM
posted by JMartz
on July 19, 2011 at 12:53 PM
There is a low pressure sensor on the drier. You should get an ohm/voltmeter and start troubleshooting
http://www.300zx-twinturbo.com/cgi-bin/manual.cgi?list=ha&dir=&config=&refresh=&slide=82&cycle=off&scale=0&design=default&total=168
Air conditioning question...
JMartz
10:06:56 07/19/11
Did you check the wire coming off of the compressor?
Woody75 (Denver)
10:20:44 07/19/11
JMartz
12:53:41 07/19/11
Re: Hey Woody, removed shroud, fan and rad to gain access -
Onyxblue
17:06:03 07/19/11
Thanks for the tip.
JMartz
19:24:32 07/19/11
I ran a ground to the frame as a temp fix.
ELDIABLO
10:52:24 07/21/11
you're probably overcharged unless you had a leak
aliaZ
22:28:19 07/20/11
stop guessing and throw some gauges on your system
aliaZ
17:25:29 07/19/11
Adding refigerant did not restart the compressor. (n/m)
JMartz
09:03:41 07/20/11
Figured out the problem...
JMartz
09:02:41 07/20/11
the same happened to my 240sx
aliaZ
22:26:31 07/20/11
