TwinTurbo.NET: Nissan 300ZX forum - Re: Please read.
Subject Re: Please read.
Posted by nikko7mge on July 18, 2011 at 10:16 PM
  This message has been viewed 124 times.
In Reply To Please read. posted by ZTurboFan on July 18, 2011 at 08:06 PM
Message Thanks for all the responses. I was under the impression that all the marks would line up if the crank is turned a certain number of revolutions. I do realize that there are timing marks on the passenger side of the engine. They also line up. There are no odd sounds when turning the engine, and as stated, compression is good in all cylinders. I've swapped the ignition transistor and no change. I can't even get a "pop" with starting fluid. I have fuel, spark, and compression... maybe not at the same time. Faulty CAS?
