TwinTurbo.NET: Nissan 300ZX forum - Air should only travel one way through the pcv's. If you got
Bo (Houston)
on July 18, 2011 at 5:19 PM
Re: brand new PCV's, new silicon hoses.
posted by supermario680
on July 18, 2011 at 04:56 PM
a lot of air traveling from the intake manifold into the crankcase then you need to get new ones. If they or one is stuck open you can sometimes fix that with wd40.
Boost leaking from oil dipstick hole!
fuzzymonkey
14:54:43 07/18/11
yes. because of the PCV's... (n/m)
supermario680
15:30:18 07/18/11
brand new PCV's, new silicon hoses. (n/m)
fuzzymonkey
16:41:28 07/18/11
supermario680
16:56:58 07/18/11
Air should only travel one way through the pcv's. If you got -
Bo (Houston)
17:19:00 07/18/11
clean them out with carb cleaner and a blow gun then put
Bo (Houston)
17:35:45 07/18/11
In this case it has nothing to do with the pcv's. (n/m)
Woody75 (Denver)
21:56:53 07/18/11
Maybe your forgetting about the breather tubes in the front
supermario680
07:57:04 07/19/11
Re: Maybe your forgetting about the breather tubes in the front
Bo (Houston)
17:06:08 07/19/11
Normal (n/m)
spicyZ
14:18:53 07/19/11
