TwinTurbo.NET: Nissan 300ZX forum - Use an ohm meter to determine how much current is drawn
Subject Use an ohm meter to determine how much current is drawn
Posted by Gordo 93TT Daytona on July 17, 2011 at 10:56 PM
  This message has been viewed 173 times.
In Reply To Battery dies overnight on my 1990 2+2. When I pull all the posted by z32z on July 17, 2011 at 09:50 PM
Message Shut off the engine, and disconnect the neg battery terminal. Put an ohm meter in line (series) w/ the negative side of the battery and the cable running down the firewall. The meter will will tell you how much current in milliamps is being used by the car's electrical system when it is shut off at the ignition switch.
The start pulling the primary fuses in front of the battery. Each of these is a major separate system. One of them will be much higher than the other. That is the one to focus on.
_________________________________________________
