TwinTurbo.NET: Nissan 300ZX forum - More than likely an injector
Subject More than likely an injector
Posted by DE944 on July 17, 2011 at 12:49 AM
  This message has been viewed 89 times.
In Reply To Sounds liks a classic injector o-ring posted by DE944 on July 15, 2011 at 11:06 PM
Message It would be almost impossible to mess up a water line and have it feed into the intake. There are no intake entry points for that to happen. On top of that, an injector o ring can have a leak that seems almost intermittent, and will almost always fade as RPM's increase, and get worse at idle. Its' leakage rate is dependent on variable fuel pressure and RPMs combined. Test your fuel pressure first. Check the FAQ section, there are a couple of good write-ups on the dremel method of changing injectors. this way you will not have to pull the plenum. If you do choose to (or need to) pull the plenum, then go ahead and do the water line bypass. It will make things much easier in the future. Hope that this helps.
