TwinTurbo.NET: Nissan 300ZX forum - DS Turbo oil return hose rubbing on steering knuckle
Subject DS Turbo oil return hose rubbing on steering knuckle
Posted by Sly on July 16, 2011 at 7:41 PM
  This message has been viewed 629 times.
Message Driver side turbo oil return hose started rubbing through from hitting the steering knuckle bolt. Something I spotted before it turned into a leak so I ordered a new one thinking I just need to trim it more.
With the Hose off turning the stering shaft it almost hits the bottom of the fitting bolted into the turbo.
If I put a new one on the way it is it will def. rubb through again.
Has anyone run into this before or are there any other suggestions
