TwinTurbo.NET: Nissan 300ZX forum - Find a good used cluster....
Subject Find a good used cluster....
Posted by white22sky on July 16, 2011 at 4:37 PM
  This message has been viewed 89 times.
In Reply To Speedo dead, odometer fine. posted by tlequeux on July 16, 2011 at 04:00 PM
Message you can also verify the speed sensor is not an issue by performing the ecu diag check for a code 14 ( the how to perform ecu test is in tech section faq) I doubt it is a problem from what your telling us. Your hicas will still work as long as the speed sensor isnt bad. I assume you do not have a hicas warning light coming on. Hope this helps
" I told my son, you have to catch the football other wise this just
looks like child abuse." - My brother
