TwinTurbo.NET: Nissan 300ZX forum - Speedo dead, odometer fine.
Subject Speedo dead, odometer fine.
Posted by tlequeux on July 16, 2011 at 4:00 PM
  This message has been viewed 109 times.
Message I have read that the speed sensor is like an on/off switch sending pulses to the ECU so I figure if the odometer still works then the issue can't be the VSS.
My question is: Since the problem seems to reside in the speedometer gauge itself, does this effect low/high speed steering adjustments and hicas?
And is there a way to purchase just the speedometer gauge without an entire cluster?
