TwinTurbo.NET: Nissan 300ZX forum - Re: Sounds liks a classic injector o-ring
Subject Re: Sounds liks a classic injector o-ring
Posted by Michaels90na+1 on July 16, 2011 at 1:45 PM
  This message has been viewed 111 times.
In Reply To Sounds liks a classic injector o-ring posted by DE944 on July 15, 2011 at 11:06 PM
Message Wouldnt I have to still remove the entire plenum again even if I did track it down to the leaking oring? Another thing is it possible that one of the coolant lines under the plenum like for the throttle botties got cracked somehow somewhere causing coolant to leak into the intake? Seems like a HUGE amount of smoke for a pinched oring. Plus it went away for a while, ran great, then came back smoking again with a hesitation like situation when revved up. When driven, the higher you rev it up the better it runs.
Click to View more pics
