TwinTurbo.NET: Nissan 300ZX forum - Sounds liks a classic injector o-ring
Subject Sounds liks a classic injector o-ring
Posted by DE944 on July 15, 2011 at 11:06 PM
  This message has been viewed 138 times.
In Reply To Injector Replacement Post install problems posted by Michaels90na+1 on July 15, 2011 at 07:52 PM
Message This sounds exactly like a pinched lower injector o-ring. Do a fuel pressure test. Test the fuel pressure eat idle and note the pressure reading. Shut the engine off and watch the gauge. If pressure bleeds off then you have an injector o ring leaking. If this is the case, you will have to test each injector. Dont do this by unplugging an injector connector with the engine running, as you can fry the ECU. Use the search and FAQ sections on this site. there are some write-ups that detail ways to track down the leak and fix it without a ton of rework. Hope this helps. Keep us posted.
