TwinTurbo.NET: Nissan 300ZX forum - Could be the EPROM
Could be the EPROM
Stadsport (PHX)
on July 15, 2011 at 8:08 PM
Yes, it will hold 650 rpm with the valve diabled.
posted by JMartz
on July 15, 2011 at 05:42 PM
Some set their idle a bit high. Could also be your TPS set incorrectly.
Setting the idle
JMartz
13:32:28 07/15/11
Throttle cable too tight? (n/m)
RVAZ
15:15:37 07/15/11
Throttle cable adjusted properly. Butterflys are
JMartz
17:44:26 07/15/11
Does it set to 20% open, and idle around 650 when disabled? (n/m)
BoneZ
15:25:36 07/15/11
JMartz
17:42:20 07/15/11
Could be the EPROM -
Stadsport (PHX)
20:08:18 07/15/11
That is where I'm thinking the problem lies.
JMartz
08:28:21 07/16/11
And the idle switch? (n/m)
Stadsport (PHX)
11:19:59 07/16/11
Where is this switch and what does it do? (n/m)
JMartz
14:47:39 07/16/11
Re: Where is this switch and what does it do?
Stadsport (PHX)
19:10:05 07/16/11
If you have conzult it shows you-IDK about other programs. (n/m)
BoneZ
22:30:51 07/15/11
I do have a ConZult. What is IDK?
JMartz
08:27:15 07/16/11
I Don't Know- IDK (n/m)
90GoldZ
12:35:30 07/16/11
Beside the inlet controlled by the IACV,
JMartz
08:36:24 07/16/11
