TwinTurbo.NET: Nissan 300ZX forum - Injector Replacement Post install problems
Subject Injector Replacement Post install problems
Posted by Michaels90na+1 on July 15, 2011 at 7:52 PM
  This message has been viewed 113 times.
Message Having some issues after replacing the injectors on a 91NA. I replaced all the seals associated with OEM and made sure they all seated correctly taking my time. After finishing the job I am having A huge amount of smoke from the tail pipes and Im thinking it may be a coolant line mismatched for a vacuum line if that is even possible. I would think it would hydrolock if that was the case but it does run. It goes back and forth from running good with no smoke to running OK with a hesitation and tons of smoke. Ive checked over all vacuum lines I can see but alot of the hoses are under the plenum. I would have done the bypasses but the car does not belong to me, but to my dad, and he likes stock everything even though I know it would have helped ALOT to bypass them. Ive been out of the Z scene for over 10 years but am a certified mechanic and recieved a degree from Wyoming technical Institute so am capable of most anything. This though is getting to me and could use some tips if anyone could help. Thank you
Click to View more pics
