TwinTurbo.NET: Nissan 300ZX forum - Clutch slipping after warm up. It's a 91 clutch master?
Subject Clutch slipping after warm up. It's a 91 clutch master?
Posted by sunroof446 on July 14, 2011 at 10:04 PM
  This message has been viewed 118 times.
Message I have adjusted the pedal several times. I also flushed the system & used wilwood brake fluid & that did help. But did not totally solve the problem. When the car is cold the pedal is real easy to push. After it warms up the pedal gets stiffer. Is there any remedys to fix this? I know there is a tsb about this to use the 92 & up master & return spring does this solve the problem.
