TwinTurbo.NET: Nissan 300ZX forum - Inside the pump there is a
Subject Inside the pump there is a
Posted by Sleeper_TTZ(SeKy) on July 13, 2011 at 4:21 PM
  This message has been viewed 105 times.
In Reply To No Front Washer. Washer Warning Light On. Fluid Full. posted by Gordo 93TT Daytona on July 13, 2011 at 04:15 PM
Message small fan attached to the motor. Most likely that fan has came off the shaft or some how bot stripped out. All the pump is, is an electric motor, the shaft goes through a rubber seal into a plastic chamber. Inside the plastic chamber is said fan. Its a semi circle shaft with a flat side. Now hard to take apart. I can't remember which pump push's to the front.
