TwinTurbo.NET: Nissan 300ZX forum - I have a 92 and mine started as a squeak, which turned into
Subject I have a 92 and mine started as a squeak, which turned into
Posted by ZX-infinity (Dallas) on July 13, 2011 at 5:44 PM
  This message has been viewed 137 times.
In Reply To Noisy Clutch posted by CollinBoz on July 13, 2011 at 03:11 PM
Message popping sound. I believe there's a TSB for early model clutch master rods having this problem. The solution was to grind down the end that pushes into the piston so it doesn't slip. I'm not sure when this was supposed to have been corrected though.
Can you tell if the squeak is coming from inside the cabin, under the hood, or under the car?
