TwinTurbo.NET: Nissan 300ZX forum - Thanks zellamay. I know I'm losing pressure.
Subject Thanks zellamay. I know I'm losing pressure.
Posted by pa300 on July 13, 2011 at 3:50 PM
  This message has been viewed 167 times.
In Reply To You are losing fuel pressure while the car sits, then it posted by zellamay on July 13, 2011 at 03:43 PM
Message However, my problem seems electrical, because the relay doesn't click and the pump doesn't humm when the key is turned on. In my mind, the priming of the system should negate the loss of pressure, since it runs fine in under other circumstances.
So why (electrically speaking) wouldn't the pump get a signal to prime, but then get the signal to run when cranking over? I'm stumped.
And thanks for the speady response again. If I ever meet you I'll buy you a case of beer.
