TwinTurbo.NET: Nissan 300ZX forum - Which Injector Switched Power mod is the best?
Subject Which Injector Switched Power mod is the best?
Posted by Gordo 93TT Daytona on July 12, 2011 at 11:24 PM
  This message has been viewed 411 times.
Message Is there a consensus on which Injector Switched Power mod is the best? I have searched and found four (4):
A. Early Injector rewire for switched power - NobleZ 14:46:12 12/19/06 .
The first of the ‘switched injector mods’ using driver’s side fusebox connectors and relays.
B. The simplest mod so far... switched power injector rewire. - NobleZ 11:54:33 12/21/06
Cut and reconnect wires within the ECU bundles
C. How-To: Injector Switched Power Line Using Fuse Box Tap - jzack 01:02:31 07/30/06
Working with wires contain in the driver’s side fusebox
D. Switch injector voltage mod in 1, 2, 3. - DVDBURN (MD) 17:35:37 11/09/10
Cut and splice wires leading to the connectors next to the drivers side fusebox.
I am inclined to select DVDBURN’s procedure; however, I am a little confused on the separate 12v. wire to power PIN 85 in the ECU (to preserve ECU codes).
_________________________________________________
