TwinTurbo.NET: Nissan 300ZX forum - Re: a few questions regarding my injector install
Subject Re: a few questions regarding my injector install
Posted by supermario680 on July 12, 2011 at 11:47 AM
  This message has been viewed 96 times.
In Reply To a few questions regarding my injector install posted by Earls Z on July 11, 2011 at 06:19 PM
Message 1 - Very Hard, you will need to pull the transmission at the mininum and possibly the plenum.
2 - I know of a decent one on 3zc o_0 and a great rear engine shot of ash's Z that shows a super simple way to do it but I cant get the link because im at work....
Basically there are 2 larger metal hard pipes coming from the back center of the engine, one is a feed, one is a return, run a feed to each turbo, and a return the two lines on the other pipe. Sorry, don't remember which one is which though...
3 - I use a bit of sandpaper wrapped around the tip of a small flathead screwdriver to get it off. Then put some di-electric grease on when re-installing to prevent future corrosion.
