TwinTurbo.NET: Nissan 300ZX forum - Re: Depends on many many things, like: how much money
Subject Re: Depends on many many things, like: how much money
Posted by BlackTwins on July 11, 2011 at 10:39 PM
  This message has been viewed 107 times.
In Reply To Depends on many many things, like: how much money posted by zellamay on July 11, 2011 at 09:41 PM
Message :do you have? what are your plans for the car (mods, refurbish, fix which things)?, what needs fixing/replacing that you have learned about so far? that you haven't learned yet? Since you just got the car, I'd say search and read a lot. If you have just one bad injector, and need some time to figure out the car, you can dremmel and replace just that one. Be forewarned, that's a temporary fix. Search and read. You could start with the responses to pa300's inquiries.
i got the car 2 months now. just i been doing body work here an there but main thing is the motor. what i done was change the spark plugs , i learn that the injector wires has a fault cause the clips is broken from pass owner but i use paper clips to hold them down tight. i been looking for new injector clips and to replace the wires that is having short but it was causing by the pull of the main wire harness so i use a tie strap to hold it from not pulling on the fuel rail plugs. it feels smooth on the left side from standing at rear of the car. but right side exhaust feels like spiting air which one injector is bad. thats what i learn . i replace the cats brand new thinking it was choking but it was broken inside. so still had to replace it. motor has 150,000 orignal miles 1990z. whats best to do next ?
