TwinTurbo.NET: Nissan 300ZX forum - i have a similar problem
Subject i have a similar problem
Posted by fcz32 on July 11, 2011 at 1:22 PM
  This message has been viewed 104 times.
In Reply To Pesky Idle issue... kinda long so go get the popcorn posted by Firstgearlaunch(Atlanta) on July 11, 2011 at 10:03 AM
Message although it doesn't happen to my car at every stop. sometimes the idle will drop down smoothly to 800. other times after i push the clutch in the idle will just plummet and drop below 500 and then either come back up to 800 or idle at 500-600 and shake like you said. so im interested to see if you find a solution.
also check to see if pressing the brake brings your idle down. i had that problem before so my car used to shake almost every time from the idle being too low at stops. and that ended up being due to a cracked brake booster hose.
