TwinTurbo.NET: Nissan 300ZX forum - Re: Lots of oil in the drivers side recirc valve and piping.
Subject Re: Lots of oil in the drivers side recirc valve and piping.
Posted by supermario680 on July 11, 2011 at 11:55 AM
  This message has been viewed 99 times.
In Reply To Lots of oil in the drivers side recirc valve and piping. posted by Joes300zxtt on July 10, 2011 at 09:19 PM
Message the actual pcv valves are mounted under the plenum and cannot be installed backwards since only one end is threaded...
there are restrictors in the other tubes...
there are a total of 4 tubes...
2 from the front of each valve cover to the accordians...
and 2 from the rear corner of the driver side exhaust valve cover which lead to the plenum PCV...
Now which ones are you talking about exactly?
When I pulled my accordians they had a tar like gunk from the point where the crank case hose came in. (front ones)
