TwinTurbo.NET: Nissan 300ZX forum - I have been using a zirgo 16" 4000 cfm fan w/ an ashspec
Subject I have been using a zirgo 16" 4000 cfm fan w/ an ashspec
Posted by wb3ztt on July 09, 2011 at 4:36 PM
  This message has been viewed 212 times.
In Reply To What kind of eletrical fan to use? posted by JesRod on July 08, 2011 at 01:32 AM
Message shroud and a adjustable electric thermostat/ relay kit. Also installed is a koyo radiator w/ the hi flow billion thermostat ,block coolant passages cleaned up. I like to drive my z hard sometimes boosting 18-20 psi. Using a laser temp gun the temp. at the heads and the out outlet pipe going to the rad is about 195f. on a 90f+ day. The fan only cools the coolant in the rad which is normally around 170f. The car is so must quieter w/o the constant blow of the oem set up and alot easier to acess the front of the engine.
