TwinTurbo.NET: Nissan 300ZX forum - Re: pedal pressure ridiculously light
Subject Re: pedal pressure ridiculously light
Posted by supermario680 on July 06, 2011 at 10:28 AM
  This message has been viewed 106 times.
In Reply To pedal pressure ridiculously light posted by SaphireZ on July 05, 2011 at 10:22 AM
Message Doesn't grab or doesn't release?
To me, if you say the clutch doesn't engage that means its as if the pedal is always down and the pressure plate is NOT engaging the disk....
I doubt this.. So I think what you mean is clutch will not dis-engage...
I'm betting on more air bubbles.
FYI: Just because a steady stream of fluid comes out DOES NOT MEAN there ISN'T still more air bubbles trapped farther up the line!!
When I do this I just crack the bleeder wide open, then have someone pump it and just send all the fluid right through the line until I feel that AT LEAST the entire volume of fluid contained in the line has been bled out. So if there were any bubbles towards the middle or top they would be rapidly flushed out.
When I figured this out it saved me SOOOO much time bleeding...
