TwinTurbo.NET: Nissan 300ZX forum - Injector Flow check
Subject Injector Flow check
Posted by Z OLOGY on July 05, 2011 at 8:57 PM
  This message has been viewed 140 times.
Message Just installed a new EFI harness and some Used Nismo 555 injector on my brothers car which i got off a TT.net member and the #1 cylinder is not firing.
I ohm that injector and got 11.8 whiich is good.
I switched the coil pack and still that cylinder is not firing.
I checked both coil pack and injector connectors with a test light and got power.
Is there anyway of checking the injector to see if its flowing right?
I was wondering if maybe I squeezed the bottom o ring when I installed it, even thought I did use petroleum jelly and they went in pretty smooth.
Any suggestions?
I was also wonder if I could install just one OEM 370 cc injector just to see if it was a flow issue since I don't have an extra 555.
