TwinTurbo.NET: Nissan 300ZX forum - I could, and I have a compression testing hose I could use >
Subject I could, and I have a compression testing hose I could use >
Posted by my91z on July 04, 2011 at 4:19 PM
  This message has been viewed 759 times.
In Reply To Replace valve stem seals w/ heads on the engine. posted by gbhrps on July 04, 2011 at 03:33 PM
Message to pressurize the cylinders and stop the valves from dropping. Compression is OK as well.
I guess the rope method seems to give a bit of extra safety margin in that I won't run out of air (sure compressor could kick on and more than keep up), and in reading on using that tool I linked to, you are supposed to use a hammer to whack it downward with. If the valve isn't pretty solid, it may not work.
Thanks,
Mike
Click here to e-mail me!
