TwinTurbo.NET: Nissan 300ZX forum - May want to check the adjustment between the master and
Subject May want to check the adjustment between the master and
Posted by Joe@ZSpeedperformance on July 04, 2011 at 2:07 PM
  This message has been viewed 222 times.
In Reply To If you have an RPS system, try this by Mr. Gordo. posted by Worm Boy on July 02, 2011 at 03:07 PM
Message the booster, If this is too tight it will cause the same issue that occurs with the pedal adjustment being to tight and you lose the free play needed when the car heats up basically blocking the orfice to the master resovoir.
www.Zspeedperformance.com
“Better to remain silent and be thought a fool than to speak out and remove all doubt.”
