TwinTurbo.NET: Nissan 300ZX forum - is the Z suppose to have low oil pressure at idle?
JoshE300zxTT
on July 03, 2011 at 10:34 PM
Both my 300's have low oil pressure at idle....sometimes it'll go to 0 psi on the gauge, but when cruising it stays at 40 psi?......normal? :S
Josh E.
is the Z suppose to have low oil pressure at idle? -
JoshE300zxTT
22:34:08 07/03/11
Not normal. If its SOMETIMES I would say its the sensor
5280Z_nightstalker
01:00:53 07/04/11
Re: is the Z suppose to have low oil pressure at idle?
ZUL8TR
06:16:02 07/04/11
Likely your pressure sending unit
spicyZ
12:43:52 07/04/11
Having a low oil pressure reading...
TTZ'sofSWMO
12:50:05 07/04/11
ok thanks guyz! I shouldve tackled this earlier but i had
JoshE300zxTT
16:21:27 07/04/11
What type of oil filter are you using? When I used a Fram
Zblackbeast
10:26:36 07/05/11
I've have used Frams before and never saw an issue.
Woody75 (Denver)
10:43:48 07/05/11
i just use a vavoline vo33 because thats what we have at the
JoshE300zxTT
19:18:31 07/05/11
