TwinTurbo.NET: Nissan 300ZX forum - clutch pedal pressure loss when engine start frustrated
Subject clutch pedal pressure loss when engine start frustrated
Posted by SaphireZ on July 03, 2011 at 1:05 AM
  This message has been viewed 289 times.
Message I have a 1993 300zx, i just replaced the slave cylinder fluid i bled the line at the bottom so only fluid comes out put the re-attached the line, i pump the clutch pedal i get a little pressure and then the second i start the car all pressure goes away.... the pedal still comes back up doesn't stick to the ground or anything but there is a huge difference between the engine running and engine not running. After i turn the engine off, a few pumps and the pressure is back.
Any idea's?
