TwinTurbo.NET: Nissan 300ZX forum - Water feed hose leak, driver's side turbo...
JMartz
on June 30, 2011 at 12:41 PM
Water hose leak - back of engine - 94TT
posted by Zirvana
on June 30, 2011 at 10:44 AM
As Opus pictures shows, the lower section is not accessible unless you pull the tranny. The upper section, maybe.., w/o the plenum. In any case after 300,000 miles its is time to pull the motor and go through every hose and seal.
Zirvana
10:44:43 06/30/11
Re: Water hose leak - back of engine - 94TT
supermario680
10:50:32 06/30/11
At about 223K miles I replaced the fuel injectors and about
Zirvana
10:58:34 06/30/11
Re: At about 223K miles I replaced the fuel injectors and about
supermario680
11:02:46 06/30/11
At the time, I wanted to keep the car mostly in stock
Zirvana
13:26:41 06/30/11
However way you decide to tackle this,
opus300zx
11:17:40 06/30/11
Thanks for the pictures! Probably a good idea to use
Zirvana
13:10:28 06/30/11
Is silicone hose recommended for a water hose? I used
Zirvana
13:31:35 06/30/11
Just make sure they're reinforced.
opus300zx
13:49:50 06/30/11
Water feed hose leak, driver's side turbo... -
JMartz
12:41:04 06/30/11
Almost all vacuum, gas and air hoses replaced at 223K miles.
Zirvana
13:14:34 06/30/11
It's accessible....
90GoldZ
21:52:47 06/30/11
