TwinTurbo.NET: Nissan 300ZX forum - Looks like multiple areas leaking....
ZXoltan
on June 28, 2011 at 3:09 PM
UPDATE w/video >>>>
posted by TTFairladyZ
on June 28, 2011 at 03:02 PM
How much pressure are you running through the core?
So I have a sizeable boost leak coming from the pass. IC
TTFairladyZ
13:57:30 06/28/11
have a radiator repair shop weld it up? (n/m)
Crim
14:11:18 06/28/11
Great, now the OCD in me, compels me to do the same
samsungz
14:19:58 06/28/11
That weld looks awfully close to the failure point.
CoHPhasor
14:27:06 06/28/11
Bought the IC's used a year ago in the classys here (n/m)
TTFairladyZ
14:33:54 06/28/11
sidebar: what prompted you to test them after 1yr ? did
samsungz
14:43:01 06/28/11
I actually knew about the leak when I installed them.
TTFairladyZ
15:11:46 06/28/11
Nice find b4 hand! :) (n/m)
samsungz
15:26:07 06/28/11
Did you spray that area with soapy water? Perhaps that
zgene4
14:28:35 06/28/11
opps missed this.. 2nd (n/m)
Halo TTZ
14:56:15 06/28/11
Put IC in water. Pin point the leak. (n/m)
14:30:35 06/28/11
I have the exact same problem in the same spot
na300zx (OH)
14:42:39 06/28/11
I used to work on air to air heat exchangers
BlackholeZ
14:51:50 06/28/11
spray bottle with soapy water..
Halo TTZ
14:55:09 06/28/11
UPDATE w/video >>>>
TTFairladyZ
15:02:55 06/28/11
Looks like multiple areas leaking.... -
ZXoltan
15:09:41 06/28/11
Only 5psi (n/m)
TTFairladyZ
15:29:25 06/28/11
ewwwwwwwww (n/m)
Halo TTZ
15:15:40 06/28/11
No techno music, no care. (n/m)
zgene4
15:55:09 06/28/11
I'd lower the pressure so that the exact locations
Barry (NJ)
16:38:52 06/28/11
2nd,
BlackholeZ
17:30:09 06/28/11
Had the same problem with mine...
Zbullet
20:43:10 06/28/11
Re: So I have a sizeable boost leak coming from the pass. IC
supermario680
09:02:50 06/30/11
