TwinTurbo.NET: Nissan 300ZX forum - pinched o-rings on the cylinders not firing would
doug8867
on June 24, 2011 at 10:50 AM
Troubles after injector swap w/ plenum pull
posted by halcyoncloud
on June 24, 2011 at 08:54 AM
seem to be a likely cause. Or possibly if the injectors are not fully seated. But in any event you'll need to pull the plenum to check them if you haven't dremeled your plenum previously to allow removal of the injectors with the plenum on.
halcyoncloud
08:54:02 06/24/11
You pinched an O-Ring. Take the injector....
HK'S Z
10:31:38 06/24/11
2nd. I've had this happen recently to me as well. (n/m)
Haasz32
11:49:06 06/24/11
Did you also install the Selin translator with your Selin->
Bo (Houston)
10:35:29 06/24/11
Yeah and you may have contaminated your oil with all-->
Bo (Houston)
10:48:15 06/24/11
Re: Did you also install the Selin translator with your Selin->
halcyoncloud
11:43:44 06/24/11
pinched o-rings on the cylinders not firing would -
doug8867
10:50:38 06/24/11
