TwinTurbo.NET: Nissan 300ZX forum - Re: Re: 500+ hp on stockers? That's crazy talk.
Subject Re: Re: 500+ hp on stockers? That's crazy talk.
Posted by jaidieray on June 22, 2011 at 8:10 PM
  This message has been viewed 116 times.
In Reply To Re: 500+ hp on stockers? That's crazy talk. posted by preprodigy on June 22, 2011 at 04:13 PM
Message Have them balance your rotating assembly,micro-polish crank,install new valve stem seals for you. Dont walk in there and tell them to regardless skim the heads and block,only if it needs it. The heads are allowed to be .004 out of flat, the block is allowed to be .004 out of flat as well. The heads are aluminum and most likely need to be skimmed however the block may not need it. [ http://300zx-twinturbo.com/cgi-bin/manual.cgi?list=em&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=29&design=default&total=70 ]
[ http://300zx-twinturbo.com/cgi-bin/manual.cgi?list=em&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=52&design=default&total=70 ]
If you take it to a shop not experienced with vg's I suggest printing out the pertinent info from the fsm and bringing it with you. Why not oem bearings?
90na2tt swap KH2 charcoal 5spd
93tt 5spd AH3=sold 90na auto EJO=sold
06 spec v=sold 95 awd talon=sold
