TwinTurbo.NET: Nissan 300ZX forum - Under the drivers's side of the plenum there is
Subject Under the drivers's side of the plenum there is
Posted by JMartz on June 21, 2011 at 6:07 PM
  This message has been viewed 165 times.
In Reply To Plenum Re-install Question posted by Joeman on June 21, 2011 at 05:25 PM
Message a metal tube array cointaing coolant and vacuum lines. The coolant one is the larger of the 2. The hose from the canister goes to just behind the DS TB. Thd tube array passes under the plenum and exits near the IACV. Another short hose connects to the balsnce tube. If you have removed the metal tube array because you are deleting the TB coolant circulation, then you can go directly to the balance tube.
