TwinTurbo.NET: Nissan 300ZX forum - Rear HICAS line removal help.
Subject Rear HICAS line removal help.
Posted by PCVI on June 21, 2011 at 12:17 PM
  This message has been viewed 169 times.
Message I've already gotten all the stuff taken care of up front to allow full removal of rear lines. But I'm having problems getting the last bit, and have not seen any posts address the rear lines specifically.
From where the two hoses connect to the rear rack, they go into "object unknown" attached to a bracket. One hose is easily removable, the other's banjo is right next to the spare tire well, so it seems that maybe the way to access this is to remove the bracket?
Obviously I want both hoses removed completely, but the unknown object as well. But can't seem to figure out how to get to it. I'd just wrestle with the bracket if I know for sure that's the answer, but I see something labeled with KYB also attached to it, which I assume is an actuator solenoid? Even though I have my actuators removed, I'd rather disturb as little as possible. It almost seems as though the unknown object is one and the same, but that doesn't make sense.
