TwinTurbo.NET: Nissan 300ZX forum - You can't compare 3 small balance tube holes with 2 wide
Bo (Houston)
on June 21, 2011 at 11:14 AM
Re: doesn't matter if your balance tube is removed
posted by white22sky
on June 21, 2011 at 10:03 AM
open throttle bodies. You should get the correct results If you check your compression with the motor nice and warm and have the petal to the floor with your balance tube on. And a good battery.
Is this typical? Slightly concerned.....
white22sky
20:22:50 06/20/11
Were all test conditions (other than a very warmed
jzack
22:32:05 06/20/11
Forgot to open the tbs
white22sky
07:14:56 06/21/11
Haha yes. (n/m)
Bo (Houston)
07:25:53 06/21/11
Re: Forgot to open the tbs
white22sky
07:47:14 06/21/11
doesn't matter if your balance tube is removed (n/m)
aliaZ
09:56:34 06/21/11
white22sky
10:03:28 06/21/11
You can't compare 3 small balance tube holes with 2 wide -
Bo (Houston)
11:14:46 06/21/11
Re: You can't compare 3 small balance tube holes with 2 wide
white22sky
11:36:59 06/21/11
have you tried it?
aliaZ
12:14:29 06/21/11
Re: have you tried it?
white22sky
12:52:23 06/21/11
Stupid question.
white22sky
14:50:52 06/21/11
Yes - and just a very small amount of oil. Best thing
jzack
20:43:55 06/21/11
