TwinTurbo.NET: Nissan 300ZX forum - Are you removing the IACV plug before turning the screw?
ZiNnYc
on June 19, 2011 at 7:28 PM
Found a few things
posted by white22sky
on June 19, 2011 at 05:53 PM
As far as whistling, check for an exhaust leak, common area is the downpipes
CPs are all same part number?
Help with engine miss at idle
white22sky
09:02:29 06/18/11
I've had the same thing for years, never have figured it out
my91z
18:43:09 06/18/11
Re: I've had the same thing for years, never have figured it out
white22sky
19:59:29 06/18/11
What plugs are you running? (n/m)
Draker (Eugene, OR)
01:06:21 06/19/11
pfr6b-11b have also tried the copper plugs
white22sky
09:12:16 06/19/11
You need to be running pfr5b-11b.
Draker (Eugene, OR)
22:33:36 06/19/11
Here is my original post.
Draker (Eugene, OR)
01:07:15 06/20/11
It's wrong?
white22sky
09:19:44 06/20/11
Yes that's wrong.
Draker (Eugene, OR)
11:48:23 06/20/11
Re: Yes that's wrong.
white22sky
12:20:39 06/20/11
Please follow up after replacing plugs.
Draker (Eugene, OR)
17:09:33 06/20/11
Deffinetly will follow up.
white22sky
18:35:20 06/20/11
CPs all the same? ohm out?
ZiNnYc
02:05:25 06/19/11
Re: CPs all the same? ohm out?
white22sky
09:27:14 06/19/11
Found a few things
white22sky
17:53:04 06/19/11
Are you removing the IACV plug before turning the screw? -
ZiNnYc
19:28:40 06/19/11
No I just warmed the car up
white22sky
19:50:22 06/19/11
