TwinTurbo.NET: Nissan 300ZX forum - Found a few things
Subject Found a few things
Posted by white22sky on June 19, 2011 at 5:53 PM
  This message has been viewed 178 times.
In Reply To Re: CPs all the same? ohm out? posted by white22sky on June 19, 2011 at 09:27 AM
Message Double checked all cps, all ok there. Pulled aac and iacv cleaned and replaced (didn't see any obvious issues). I put things back together and noticed two things (1. My problem was still there (2. I am also hearing, I think unrelated, a whistling from underneath the car. I did however notice after the car warmed up that while my miss was still there, my rpms at idle are around a little over 1g. I adjusted the screw to around 750-800 rpms. After that I let it run about 5 min and never once felt the miss that I had been. Two questions come to mind how could the adjustment screw possibly have fixed (time will tell for sure) my issue, and what the hell is this whistling noise I'm hearing?
" I told my son, you have to catch the football other wise this just looks like child abuse."
