TwinTurbo.NET: Nissan 300ZX forum - I have R32 turbos on mine. Not direct bolt up.
Subject I have R32 turbos on mine. Not direct bolt up.
Posted by Crim on June 16, 2011 at 10:41 PM
  This message has been viewed 123 times.
In Reply To GTR turbo... posted by Sketch on June 16, 2011 at 11:16 AM
Message As far as the R32 turbos go..the exhaust flange is different, you would need to modify your stock manifolds to have the appropriate flange. Where the intake pipes bolt up are clocked differently, you would need to cut, clock and re-weld the intake pipes. Outlet from the turbos will need to be modified. Oil drain tubes will need to be modified to fit. You will need 5bolt down pipes.
All in all, probably not worth it, unless you're looking for a project. I would just go with some sp500s or larger. I haven't gotten any dyno numbers since I've put these turbos on so I can't give you any real comparison between them and stockers.
1990 2+2 TwinTurbo
  • GTR turbo... - Sketch 11:16:28 06/16/11
    • I have R32 turbos on mine. Not direct bolt up. - Crim 22:41:49 06/16/11
