TwinTurbo.NET: Nissan 300ZX forum - Re: Any codes from the ECU? Idle set correctly?
skperkins144
on June 12, 2011 at 7:15 PM
Any codes from the ECU? Idle set correctly? (n/m)
posted by Crim
on June 12, 2011 at 06:51 PM
No check engine light except when I forgot to plug the maf in, and unless I accedently moved the idle adjustment screw but I will check it, do I turn it clockwise to increase idle rpm?
rebuilt motor stalls
skperkins144
17:56:06 06/12/11
Crim
18:51:15 06/12/11
Re: Any codes from the ECU? Idle set correctly? -
skperkins144
19:15:08 06/12/11
The ECU can throw codes and not show a CEL on the dash
Crim
23:53:04 06/12/11
skperkins144
19:16:01 06/12/11
hopefully gurus will chime in (n/m)
skperkins144
20:12:19 06/12/11
Any pics of your fuel line routing?
Woody75 (Denver)
20:17:54 06/12/11
Re: Any pics of your fuel line routing?
skperkins144
20:43:54 06/12/11
Did you do anything at the fuel pump bulkhead? (n/m)
ZiNnYc
20:56:01 06/12/11
no (n/m)
skperkins144
21:03:59 06/12/11
Regulator goes at the end of the route, not beginning.
Woody75 (Denver)
21:35:16 06/12/11
Re: Regulator goes at the end of the route, not beginning.
skperkins144
21:47:57 06/12/11
oops (n/m)
aliaZ
20:11:09 06/13/11
Re: oops
skperkins144
10:40:04 06/15/11
