TwinTurbo.NET: Nissan 300ZX forum - Re: OK TT.Net Gurus, could my ECU be going or what?
Subject Re: OK TT.Net Gurus, could my ECU be going or what?
Posted by txq45 on June 12, 2011 at 5:34 PM
  This message has been viewed 235 times.
In Reply To OK TT.Net Gurus, could my ECU be going or what? posted by 91z tt on June 11, 2011 at 10:27 AM
Message I've had more than 3 ECU's with bad injector circuits in the past 6 months.. Try this use an LED .. unplug number 4 insert the LED .. Also remove fuel pump fuse first.. having someone turning the key and watch the LED.. it should flash on and off.. Since the LED is directional. You may have to reverse it .. If it still does not flash on and of when the engine is turned over.. It could be the ECU or the CAS..
If using a known good CAS and it still doesn't flash ,, you may need a new ECU..
Nistune Dealer
Built Automatics -ECU socketing ECU eprom upgrades
WWW.AAA-HiperformanceAuto.com
