TwinTurbo.NET: Nissan 300ZX forum - Did you turn of the closed loop lambda correction?
Subject Did you turn of the closed loop lambda correction?
Posted by kickerzx on June 12, 2011 at 11:49 AM
  This message has been viewed 260 times.
In Reply To Lean cold idle - rich warm idle - Nistune w/ wideband posted by treese88 on June 12, 2011 at 09:37 AM
Message If its on the warm AFR should fluxate around 14.7 regardless.
Did you mess with the warmup enrichment? (I dont have Nistune so im not sure what exactly you can mess with)
Do the coolant temp (as read by the ECU) seem sound? If the ecu thinks the engine is warm when it is not this will happend.
Is the injector latency set correctly?
Personaly i think i would swap the DW`s and get that out of the equation right away. They are not doing anything good for you in this matter anyways.
